Saltar al contenido principal
Lenovo 100s Chromebook-11IBY Speaker Replacement
Qué necesitas
  1. Lenovo 100s Chromebook-11IBY Speaker Replacement, Speakers: paso 1, imagen 1 de 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 2, imagen 1 de 1
    • Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 3, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 3, imagen 2 de 2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 4, imagen 1 de 3 Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 4, imagen 2 de 3 Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 4, imagen 3 de 3
    • Locate the two sticker-like connecting wires (for the keyboard and touchpad).
    • Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
    • Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
    • Then lift the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 5, imagen 1 de 1
    • Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
    • Then unplug the cable attaching the right speaker by hand.
  6. Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 6, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 6, imagen 2 de 2
    • Carefully pry the speaker up and free of the two notches holding it in place.
    • Remove the speaker.
  7. Lenovo 100s Chromebook-11IBY Speaker Replacement: paso 7, imagen 1 de 1
    • Repeat steps 5 & 6 in order to remove the right speaker.
Conclusión
Una persona más ha completado esta guía.
Milton Perez
Miembro Desde 03/09/17
630 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S7-G2, Cagle Spring 2017 Miembro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Miembro
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 510
