Saltar al contenido principal
Lenovo 100s Chromebook-11IBY Screen Replacement
Qué necesitas
  1. Lenovo 100s Chromebook-11IBY Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 3, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Screen Replacement: paso 3, imagen 2 de 2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 4, imagen 1 de 1
    • Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 5, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Screen Replacement: paso 5, imagen 2 de 2
    • Use the #0 Phillips screwdriver to remove the four 6mm screws from the screen.
  6. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 6, imagen 1 de 1
    • Gently remove the screen from the plate and place it on the keyboard.
    • Be careful not to pull screen the immediately or completely out because cables are attached.
  7. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 7, imagen 1 de 1
    • Gently remove the adhesive tape from the back of the screen.
  8. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 8, imagen 1 de 1
    • Unplug the screen from the laptop.
  9. Lenovo 100s Chromebook-11IBY Screen Replacement: paso 9, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Screen Replacement: paso 9, imagen 2 de 2
    • The screen may now be removed completely from the laptop.
    • The back side of the screen has the screen's model number and manufacturer.
Conclusión
Una persona más ha completado esta guía.
Milton Perez
Miembro Desde 03/09/17
630 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S7-G2, Cagle Spring 2017 Miembro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Miembro
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,865
