Saltar al contenido principal
Lenovo 100e Chromebook 2nd Gen Trackpad Replacement
Qué necesitas
  1. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: paso 2, imagen 1 de 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: paso 2, imagen 2 de 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: paso 3, imagen 1 de 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: paso 3, imagen 2 de 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Trackpad: paso 4, imagen 1 de 1
    • Remove the three 2 mm Phillips #00 screws holding the trackpad in.
  5. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: paso 5, imagen 1 de 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: paso 5, imagen 2 de 2
    • Push up on the side of the trackpad that faces the screen.
    • Pop the trackpad out and remove it from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 47
Todo El Tiempo: 1,061
