Saltar al contenido principal
Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement
Qué necesitas
  1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: paso 2, imagen 1 de 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: paso 3, imagen 1 de 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: paso 3, imagen 2 de 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Headphone Jack: paso 4, imagen 1 de 1
    • Remove the three 4 mm Phillips #0 screws holding the headphone jack in place.
  5. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Using a plastic opening pick, remove the connection between the aux port and the speakers.
  6. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening pick, pop the retaining flap holding the ribbon cable in place.
    • Remove the headphone jack from the laptop.
Conclusión
Un comentario
I believe our model has the headphone jack soldered on. Any other ideas?
L Hart - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 42
Todo El Tiempo: 907
