Introducción
This guide will show the steps needed to take out and replace the display in the Lenovo Chromebook 100e 2nd gen. You may need this guide if your display is cracked, malfunctioning, or otherwise broken.
Qué necesitas
Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
