Saltar al contenido principal
Lenovo 100e Chromebook 2nd Gen Camera Replacement
Qué necesitas
  1. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Screen Bezel: paso 1, imagen 1 de 1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  2. Lenovo 100e Chromebook 2nd Gen Camera Replacement: paso 2, imagen 1 de 1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  3. Lenovo 100e Chromebook 2nd Gen Camera Replacement: paso 3, imagen 1 de 1
    • Remove the screen bezel from the laptop.
  4. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Camera: paso 4, imagen 1 de 1
    • Using the opening pick, pry the camera from the front of the laptop.
  5. Lenovo 100e Chromebook 2nd Gen Camera Replacement: paso 5, imagen 1 de 1
    • Carefully pinch and pull on the connection between the camera and the motherboard.
    • The camera is now loose and can be removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 494
