Herramientas
Partes
No se requieren partes.
  1. Carefully unscrew the four (4) screws on the bottom of the camera.
    • Carefully unscrew the four (4) screws on the bottom of the camera.
    • Make sure you don't miss the one that's actually in the tripod socket hole.
  2. Open the back door on the camera by pushing down on the door latch.
    • Open the back door on the camera by pushing down on the door latch.
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
    • Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
    • The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
    • Apply pressure until the piece you unscrewed in the last step pops off.
    • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
    • Removing the lens motor cover, you should be left with these four pieces.
    • Located underneath these four pieces is the lens motor.
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
    • You should now have removed the front and back plates.
    • Remove the four screws holding on the front panel surrounding the lens.
    • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
    • Now that the lens motor has been removed, you can apply pressure to the back of the lens and push it out.
    • From here, locate the three screws near the front of the lens.
    • Unscrew these three screws.
    • From here, you can pull out the small disk containing the lens cover.
    • Unscrew the four screws on the back and pull the two pieces of the disk apart.
    • From here, you can replace any broken parts in the lens cover.
Conclusión
Kenny
Miembro Desde 10/04/11
51 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-19, Garner Spring 2011 Miembro de Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 9
Todo El Tiempo: 2,245
