Saltar al contenido principal
Leather Belt Strap Replacement
Qué necesitas
  1. Leather Belt Strap Replacement, Belt Strap: paso 1, imagen 1 de 2 Leather Belt Strap Replacement, Belt Strap: paso 1, imagen 2 de 2
    • Begin by turning the belt buckle around to reveal the screws at the back of the belt.
  2. Leather Belt Strap Replacement: paso 2, imagen 1 de 3 Leather Belt Strap Replacement: paso 2, imagen 2 de 3 Leather Belt Strap Replacement: paso 2, imagen 3 de 3
    • Take a small screwdriver and begin unscrewing the two screws on both sides of the belt buckle.
    • The screws are M2.5x5 Cross Slot Tip Screws for leather accessories.
  3. Leather Belt Strap Replacement: paso 3, imagen 1 de 3 Leather Belt Strap Replacement: paso 3, imagen 2 de 3 Leather Belt Strap Replacement: paso 3, imagen 3 de 3
    • Remove the unscrewed belt buckle away from the old leather strap.
  4. Leather Belt Strap Replacement: paso 4, imagen 1 de 3 Leather Belt Strap Replacement: paso 4, imagen 2 de 3 Leather Belt Strap Replacement: paso 4, imagen 3 de 3
    • Take new leather belt strap and align it with the old leather strap.
    • Take a pen and approximately mark the areas where the cuts will be made.
  5. Leather Belt Strap Replacement: paso 5, imagen 1 de 2 Leather Belt Strap Replacement: paso 5, imagen 2 de 2
    • Take the pen.
    • Draw two circles where the screws will be screwed in.
  6. Leather Belt Strap Replacement: paso 6, imagen 1 de 3 Leather Belt Strap Replacement: paso 6, imagen 2 de 3 Leather Belt Strap Replacement: paso 6, imagen 3 de 3
    • Take the new leather belt strap with markings made.
    • Use a scissor to cut out the square mark on the new leather belt strap.
  7. Leather Belt Strap Replacement: paso 7, imagen 1 de 3 Leather Belt Strap Replacement: paso 7, imagen 2 de 3 Leather Belt Strap Replacement: paso 7, imagen 3 de 3
    • Take a small screwdriver and puncture the two small circles on the new leather belt strap.
    • Make sure that the holes are punctured through.
    • If the screwdriver is not sharp enough to puncture the hole, you may use a small sharp object such as a hand held needle.
  8. Leather Belt Strap Replacement: paso 8, imagen 1 de 3 Leather Belt Strap Replacement: paso 8, imagen 2 de 3 Leather Belt Strap Replacement: paso 8, imagen 3 de 3
    • Now, take the front side of the belt buckle and insert it into the front side of the new leather belt strap.
    • If the belt buckle does not fit in, make the markings bigger by cutting away excess leather.
  9. Leather Belt Strap Replacement: paso 9, imagen 1 de 3 Leather Belt Strap Replacement: paso 9, imagen 2 de 3 Leather Belt Strap Replacement: paso 9, imagen 3 de 3
    • Turn the belt buckle to the back.
    • Take the small screwdriver and the screws.
    • Begin screwing back the screws onto the belt buckle.
    • Make sure the screws are tightly screwed in.
  10. Leather Belt Strap Replacement: paso 10, imagen 1 de 3 Leather Belt Strap Replacement: paso 10, imagen 2 de 3 Leather Belt Strap Replacement: paso 10, imagen 3 de 3
    • Now take the old and new leather belt strap
    • Align both leather belt straps side by side. (The old leather belt strap will be used as a reference)
    • Use a pen to draw circles that are an equal distance apart.
    • Start by drawing the same number of circles that are on the old belt strap.
  11. Leather Belt Strap Replacement: paso 11, imagen 1 de 3 Leather Belt Strap Replacement: paso 11, imagen 2 de 3 Leather Belt Strap Replacement: paso 11, imagen 3 de 3
    • Take the revolving leather puncher.
    • Rotate the setting clockwise to the third or fourth-largest setting. (This will ensure that the buckle's prong will fit through the holes)
    • Now insert the leather puncher and align it with the circle.
    • To punch a hole through the leather, squeeze the handle thoroughly until the leather punch clicks.
  12. Leather Belt Strap Replacement: paso 12, imagen 1 de 3 Leather Belt Strap Replacement: paso 12, imagen 2 de 3 Leather Belt Strap Replacement: paso 12, imagen 3 de 3
    • THIS STEP IS OPTIONAL
    • Use the pen to draw detail marking to the end of the new leather belt strap.
    • Take the kitchen scissors and cut the leather belt according to the detail.
  13. Leather Belt Strap Replacement: paso 13, imagen 1 de 1
    • FINISH PRODUCT
    • If the new belt is too loose, consider adding additional holes to the belt.
Conclusión
Dat Lam
Miembro Desde 03/25/24
217 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 52
