Saltar al contenido principal
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
Qué necesitas
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: paso 1, imagen 1 de 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 2, imagen 1 de 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 3, imagen 1 de 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 3, imagen 2 de 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: paso 4, imagen 1 de 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 5, imagen 1 de 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 6, imagen 1 de 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 6, imagen 2 de 2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 7, imagen 1 de 1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 8, imagen 1 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 8, imagen 2 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 8, imagen 3 de 3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 9, imagen 1 de 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 9, imagen 2 de 2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 10, imagen 1 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 10, imagen 2 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: paso 10, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 14-6, Lacy Spring 2016 Miembro de USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Miembros
6 Guías creadas
6 comentarios
Very useful. but where to get a new membrane? please help
Alina Timchenko - Contestar
Didn't work. I'll buy a new toy.
victoria_nglover19 - Contestar
Is the screen on this suppose to light up?
stewartmelinda41 - Contestar
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 49
Todo El Tiempo: 5,266
