Saltar al contenido principal
Leapfrog My Own Leaptop Battery Replacement Guide
Qué necesitas
  1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: paso 1, imagen 1 de 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Battery Replacement Guide: paso 2, imagen 1 de 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Battery Replacement Guide: paso 3, imagen 1 de 2 Leapfrog My Own Leaptop Battery Replacement Guide: paso 3, imagen 2 de 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
Linea de Meta
Una persona más ha completado esta guía.
Jonathan Fitzer
Miembro Desde 02/10/16
584 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 14-6, Lacy Spring 2016 Miembro de USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Miembros
6 Guías creadas
Un comentario
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 24
Ultimos 30 días: 78
Todo El Tiempo: 2,897
