Introducción
During this guide you will take apart the leapfrog and replace the board containing the speaker, audio jack, and directional pad.
Qué necesitas
Herramienta utilizada en este paso:Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Disconnect the audio cord from the motherboard using a plastic opening tool.
2 personas más completaron esta guía.
