Saltar al contenido principal
Leapfrog LeapPad 3 Motherboard Replacement
Qué necesitas
  1. Leapfrog LeapPad 3 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Leapfrog LeapPad 3 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Leapfrog LeapPad 3 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Motherboard Replacement: paso 2, imagen 1 de 3 Leapfrog LeapPad 3 Motherboard Replacement: paso 2, imagen 2 de 3 Leapfrog LeapPad 3 Motherboard Replacement: paso 2, imagen 3 de 3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Motherboard Replacement: paso 3, imagen 1 de 2 Leapfrog LeapPad 3 Motherboard Replacement: paso 3, imagen 2 de 2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  5. Leapfrog LeapPad 3 Motherboard Replacement: paso 5, imagen 1 de 3 Leapfrog LeapPad 3 Motherboard Replacement: paso 5, imagen 2 de 3 Leapfrog LeapPad 3 Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  6. Leapfrog LeapPad 3 Motherboard Replacement: paso 6, imagen 1 de 3 Leapfrog LeapPad 3 Motherboard Replacement: paso 6, imagen 2 de 3 Leapfrog LeapPad 3 Motherboard Replacement: paso 6, imagen 3 de 3
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
Conclusión
4 personas más completaron esta guía.
Matt Irvine
Miembro Desde 02/04/16
952 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 16-2, Blackwell Winter 2016 Miembro de USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Miembros
12 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,442
