Introducción
This guide will involve taking the case off of the Leapfrog and removing the motherboard.
Herramientas
Partes
No se especificaron partes.
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Disconnect the audio cord from the motherboard using a plastic opening tool.
Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
Unscrew the eight 6.5 mm phillips screws from the plastic casing.
2 personas más completaron esta guía.
