Saltar al contenido principal
LeapFrog Scribble and Write Eraser Slider Cleaning
Qué necesitas
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: paso 1, imagen 1 de 1
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: paso 3, imagen 1 de 1
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: paso 4, imagen 1 de 2 LeapFrog Scribble and Write Eraser Slider Cleaning: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: paso 5, imagen 1 de 1
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: paso 6, imagen 1 de 2 LeapFrog Scribble and Write Eraser Slider Cleaning: paso 6, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: paso 7, imagen 1 de 1
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
Conclusión
Shang
Miembro Desde 02/10/16
328 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-5, Nance Spring 2016 Miembro de USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 671
