Saltar al contenido principal
LeapFrog LeapPad2 Explorer Speaker Replacement
Qué necesitas
  1. LeapFrog LeapPad2 Explorer Speaker Replacement, Battery: paso 1, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Speaker Replacement: paso 2, imagen 1 de 3 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 2, imagen 2 de 3 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 2, imagen 3 de 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Speaker Replacement, Back Cover: paso 3, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement, Back Cover: paso 3, imagen 2 de 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Speaker Replacement: paso 4, imagen 1 de 3 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 4, imagen 2 de 3 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 4, imagen 3 de 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Speaker Replacement, Front Cover: paso 5, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement, Front Cover: paso 5, imagen 2 de 2
    • Remove the following screws securing the front cover to the main device:
    • Three 6.0 mm Phillips screws
    • Three 7.0 mm Phillips screws
    • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
    • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
  6. LeapFrog LeapPad2 Explorer Speaker Replacement: paso 6, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 6, imagen 2 de 2
    • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
  7. LeapFrog LeapPad2 Explorer Speaker Replacement: paso 7, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
    • Use tweezers to remove the piece.
    • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
  8. LeapFrog LeapPad2 Explorer Speaker Replacement: paso 8, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 8, imagen 2 de 2
    • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • For proper soldering and desoldering techniques reference Cómo soldar y desoldar conexiones.
    • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
    • Be extremely careful with the cables in this step as they could melt, burn, or break.
  9. LeapFrog LeapPad2 Explorer Speaker Replacement: paso 9, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement: paso 9, imagen 2 de 2
    • Pry the power cables from the device using your fingers or tweezers.
    • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
  10. LeapFrog LeapPad2 Explorer Speaker Replacement, Speaker: paso 10, imagen 1 de 2 LeapFrog LeapPad2 Explorer Speaker Replacement, Speaker: paso 10, imagen 2 de 2
    • Finally, locate and desolder the remaining connections from speaker wires on the circuit.
    • Once finished desoldering, flip to the other side of the circuit board to remove the wires.
    • Reference How To Solder and Desolder Connections to learn how to solder.
Conclusión
Una persona más ha completado esta guía.
Nupur Garg
Miembro Desde 04/12/14
867 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2014 Miembro de Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Miembros
16 Guías creadas
Un comentario
What type of speaker do I need to use to replace it with?
Bond Dye - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 4,391
