Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LeapFrog LeapPad2 Explorer Front Cover Replacement
Qué necesitas
    1. LeapFrog LeapPad2 Explorer Front Cover Replacement, Battery: paso 1, imagen 1 de 2 LeapFrog LeapPad2 Explorer Front Cover Replacement, Battery: paso 1, imagen 2 de 2
      • Before disassembling your LeapPad, ensure your device is shut off.
      • Push outward on the plastic side panels to remove and reveal battery.
      • The panels should detach fully from the main device.
      Pregunta a FixBot
      Agregar Comentario
    2. LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 2, imagen 1 de 3 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 2, imagen 2 de 3 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 2, imagen 3 de 3
      • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
      • Remove all four AA alkaline batteries from the device.
      Pregunta a FixBot
      Agregar Comentario
    1. LeapFrog LeapPad2 Explorer Front Cover Replacement, Back Cover: paso 3, imagen 1 de 2 LeapFrog LeapPad2 Explorer Front Cover Replacement, Back Cover: paso 3, imagen 2 de 2
      • This step will void your device warranty.
      • Remove the following screws securing the back cover to the main device:
      • Two 10.0 mm Phillips screws
      • Four 4.0 mm Phillips screws
      • Three 3.0 mm Phillips screws
      Pregunta a FixBot
      Agregar Comentario
    2. LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 4, imagen 1 de 3 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 4, imagen 2 de 3 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 4, imagen 3 de 3
      • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
      • Move the plastic opening tool around the perimeter of the LeapPad2.
      • Lift up and remove the rear case from the tablet.
      • A butter knife can help when prying the device.
      Pregunta a FixBot
      Agregar Comentario
    1. LeapFrog LeapPad2 Explorer Front Cover Replacement, Front Cover: paso 5, imagen 1 de 2 LeapFrog LeapPad2 Explorer Front Cover Replacement, Front Cover: paso 5, imagen 2 de 2
      • Remove the following screws securing the front cover to the main device:
      • Three 6.0 mm Phillips screws
      • Three 7.0 mm Phillips screws
      • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
      • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
      Pregunta a FixBot
      Agregar Comentario
    2. LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 6, imagen 1 de 2 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 6, imagen 2 de 2
      • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
      Pregunta a FixBot
      Agregar Comentario
    3. LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 7, imagen 1 de 2 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 7, imagen 2 de 2
      Herramienta utilizada en este paso:
      • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
      • Use tweezers to remove the piece.
      • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
      Pregunta a FixBot
      Agregar Comentario
    4. LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 8, imagen 1 de 2 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 8, imagen 2 de 2
      • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
      • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
      • For proper soldering and desoldering techniques reference Cómo soldar y desoldar conexiones.
      • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
      • Be extremely careful with the cables in this step as they could melt, burn, or break.
      Pregunta a FixBot
      Agregar Comentario
    5. LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 9, imagen 1 de 2 LeapFrog LeapPad2 Explorer Front Cover Replacement: paso 9, imagen 2 de 2
      • Pry the power cables from the device using your fingers or tweezers.
      • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Nupur Garg
Miembro Desde 04/12/14
867 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2014 Miembro de Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
Miembros de 4
108 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 26
Ultimos 30 días: 53
Todo El Tiempo: 2,050
