Saltar al contenido principal
LeapFrog LeapPad2 Explorer Back Camera Replacement
Qué necesitas
  1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: paso 1, imagen 1 de 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 2, imagen 1 de 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 2, imagen 2 de 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 2, imagen 3 de 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: paso 3, imagen 1 de 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: paso 3, imagen 2 de 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 4, imagen 1 de 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 4, imagen 2 de 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 4, imagen 3 de 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: paso 5, imagen 1 de 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: paso 5, imagen 2 de 2
    • Locate the back camera below the game cartridge.
  6. LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 6, imagen 1 de 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 6, imagen 2 de 2
    • To safely remove the ribbon cable, first you must pull up the retaining flap.
    • Removing or reinserting the cable by brute force can damage it.
  7. LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 7, imagen 1 de 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 7, imagen 2 de 2
    • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
  8. LeapFrog LeapPad2 Explorer Back Camera Replacement: paso 8, imagen 1 de 1
    • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
Conclusión
Nupur Garg
Miembro Desde 04/12/14
867 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2014 Miembro de Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,219
