Saltar al contenido principal
LeapFrog LeapPad Ultra XDi Battery Replacement
Qué necesitas
  1. LeapFrog LeapPad Ultra XDi Battery Replacement, Battery: paso 1, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Battery Replacement: paso 2, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Battery Replacement: paso 2, imagen 2 de 2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Battery Replacement: paso 3, imagen 1 de 3 LeapFrog LeapPad Ultra XDi Battery Replacement: paso 3, imagen 2 de 3 LeapFrog LeapPad Ultra XDi Battery Replacement: paso 3, imagen 3 de 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Battery Replacement: paso 4, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Battery Replacement: paso 4, imagen 2 de 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Battery Replacement: paso 5, imagen 1 de 2 LeapFrog LeapPad Ultra XDi Battery Replacement: paso 5, imagen 2 de 2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Battery Replacement: paso 6, imagen 1 de 3 LeapFrog LeapPad Ultra XDi Battery Replacement: paso 6, imagen 2 de 3 LeapFrog LeapPad Ultra XDi Battery Replacement: paso 6, imagen 3 de 3
    • Use the Spudger to remove the glued down battery.
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Replace the battery with a new one.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,139
