Introducción
This guide provides steps for replacing the audio jack in the LeapFrog LeapPad Ultra XDi (model number 33300) .
The audio jack transmits audio from the device to auxiliary devices. When this part is not working properly audio may be distorted or not audible. You should first try the audio jack troubleshooting guide before replacing the entire audio jack.
Step 10 requires you to desolder the audio jack from the motherboard and solder a the replacement audio jack. If you’re not familiar with soldering you can follow this guide for instructions. A new audio jack is also required for this guide.
Before beginning, make sure to power down the device completely and disconnect it from any power source.
Qué necesitas
Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
Remove the barcode sticker to expose the two screws.
Locate the three ribbon cables on top of the motherboard.
Flip up the locking clip on the ribbon cable connector to release the cable.
Disconnect the cables from their connectors.
