Saltar al contenido principal
LeapFrog LeapPad Ultra Repair Motherboard Replacement
Qué necesitas
  1. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 6, imagen 1 de 2 LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: paso 7, imagen 1 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: paso 7, imagen 2 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: paso 7, imagen 3 de 3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 8, imagen 1 de 1
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 9, imagen 1 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 9, imagen 2 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 9, imagen 3 de 3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove and replace motherboard.
Conclusión
Rocky Hirsch
Miembro Desde 08/27/15
902 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 4-99, Meier Fall 2015 Miembro de USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 1,650
