Saltar al contenido principal
LeapFrog LeapPad Ultimate Back Panel Replacement
Qué necesitas
  1. LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Back Panel Replacement: paso 2, imagen 1 de 2 LeapFrog LeapPad Ultimate Back Panel Replacement: paso 2, imagen 2 de 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 1,299
