Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LeapFrog LeapPad Platinum Speaker Replacement
Qué necesitas
  1. LeapFrog LeapPad Platinum Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Speaker Replacement: paso 2, imagen 1 de 2 LeapFrog LeapPad Platinum Speaker Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Speaker Replacement: paso 3, imagen 1 de 2 LeapFrog LeapPad Platinum Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Speaker Replacement: paso 4, imagen 1 de 1
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Speaker Replacement: paso 5, imagen 1 de 3 LeapFrog LeapPad Platinum Speaker Replacement: paso 5, imagen 2 de 3 LeapFrog LeapPad Platinum Speaker Replacement: paso 5, imagen 3 de 3
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Speaker Replacement: paso 6, imagen 1 de 1
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
  7. LeapFrog LeapPad Platinum Speaker Replacement, Speaker: paso 7, imagen 1 de 2 LeapFrog LeapPad Platinum Speaker Replacement, Speaker: paso 7, imagen 2 de 2
    • Remove the brown speaker board located on the left side of the LeapPad by removing the following screws holding it in place:
    • Four 3.0mm Phillips screws
    • One 7.0mm Phillips screw
  8. LeapFrog LeapPad Platinum Speaker Replacement: paso 8, imagen 1 de 2 LeapFrog LeapPad Platinum Speaker Replacement: paso 8, imagen 2 de 2
    • Locate the circular plastic speaker cover, remove the two 5.0mm Phillips screws holding it in place, and gently lift the cover away from the device.
  9. LeapFrog LeapPad Platinum Speaker Replacement: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Lift up the speaker board and locate the white ribbon attached to its underside.
    • Fully remove the speaker board from the device by gently pulling the ribbon cables out of the slot.
    • Be gentle when working with the ribbon as it can be damaged easily.
    • Tweezers or a pointed plastic spudger will help guide the ribbon back through the black tabs when reassembling your device.
Conclusión
2 personas más completaron esta guía.
Leann Nguyen
Miembro Desde 02/02/16
171 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 1-5, Rose Winter 2016 Miembro de UW Tacoma, Team 1-5, Rose Winter 2016
UWT-ROSE-W16S1G5
Miembros de 4
8 Guías creadas
1Guía Comentario
Thanks for the tutorial: Where can we find the replacement speaker?
Gigi - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 55
Todo El Tiempo: 1,774
