Introducción
Use this guide to remove all of the electrical components inside your LeapPad Platinum tablet and then replace the touch screen.
Qué necesitas
Locate the white ribbon cable connected to the motherboard.
Disconnect the cable by flipping up the metal tab on the connector and sliding the cable out.
Rotate your device 180 degrees so the the motherboard is on your right-hand side and gently lift the front edge of the motherboard to reveal an orange sheet of plastic.
Disconnect the orange sheet from the motherboard by lifting the metal tab on the connector (as you did for the cables in steps 1 and 2), and lift the motherboard completely out of the device.
Remove the brown speaker board located on the left side of the LeapPad by removing the following screws holding it in place:
Four 3.0mm Phillips screws
One 7.0mm Phillips screw
2 personas más completaron esta guía.
2 comentarios
Where can i get a replacement screen?
