Saltar al contenido principal
LeapFrog LeapPad 2 Motherboard Replacement
Qué necesitas
  1. LeapFrog LeapPad 2 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the tablet so the back is visible.
    • One at a time, remove the battery covers by sliding them towards the sides and away from the center of the device.
  2. LeapFrog LeapPad 2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the AA batteries from both battery compartments of the device.
  3. LeapFrog LeapPad 2 Motherboard Replacement, Rear Cover: paso 3, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement, Rear Cover: paso 3, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement, Rear Cover: paso 3, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the following screws from the device:
    • Four 7.0mm Phillips screws
    • Three 6.0mm Phillips screws
    • Two 10.0mm Phillips screws
    • These two screws are behind the barcode decal on the bottom of the device. Expose the screws by puncturing, cutting, or peeling the barcode decal.
  4. LeapFrog LeapPad 2 Motherboard Replacement: paso 4, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 4, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a small plastic opening tool to begin separating the colored front cover from the white rear cover of the device.
    • With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and begin pulling the pieces apart.
    • The most stubborn tabs holding the front and rear together are along the top edge of the tablet around the game cartridge slot. This will most likely be the last area that separates, and it may require a moderate amount of force.
    • Once only the top edge remains connected, simultaneously pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces together.
  5. LeapFrog LeapPad 2 Motherboard Replacement, Rear Camera: paso 5, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement, Rear Camera: paso 5, imagen 2 de 2
    • Open the camera ribbon cable connector by lifting on the brown latch with a plastic opening tool or a finger until it is in a vertical position.
    • Failing to do this correctly could result in damage to the cable and/or connector.
  6. LeapFrog LeapPad 2 Motherboard Replacement: paso 6, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use flat tweezers or fingers to pull the rear camera ribbon cable out of the motherboard's camera connector.
    • If the connector is properly open, disconnecting the ribbon cable should require little to no force.
  7. LeapFrog LeapPad 2 Motherboard Replacement: paso 7, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement: paso 7, imagen 2 de 2
    • Lift the camera body out of the plastic frame by using two small plastic opening tools as follows:
    • Place one opening tool directly under the base of the camera ribbon cable and camera body, applying upward pressure.
    • At the same time, use the other tool to release one of the clips on the left or the right of the camera body.
    • The left side of the camera body is shown here as the top, with the right side shown as the bottom.
    • Be careful not to bend the retaining clips too far as this can damage them.
  8. LeapFrog LeapPad 2 Motherboard Replacement, Front Cover: paso 8, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement, Front Cover: paso 8, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove two 5.5mm screws from the plastic speaker holder.
    • The rear camera is shown removed in these images, but its removal is optional for most tasks.
  9. LeapFrog LeapPad 2 Motherboard Replacement: paso 9, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement: paso 9, imagen 2 de 2
    • Remove the plastic speaker holder from the device.
  10. LeapFrog LeapPad 2 Motherboard Replacement: paso 10, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement: paso 10, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the following screws:
    • One 5.5mm Phillips screw holding the screen assembly.
    • Two 8.0mm Phillips screws holding the motherboard.
    • Two 6.0mm Phillips screws holding the game cartridge slot.
    • One of these screws also holds a black plastic bracket for the front camera, and the bracket is loose once the screw is removed. Set the bracket aside if it falls out.
    • Remember to replace the bracket during this step of reassembly if it was removed.
    • Three 6.0mm Phillips screws holding the auxiliary board.
    • Be careful not to damage the gray ribbon cable connecting the auxiliary board when removing these three screws.
  11. LeapFrog LeapPad 2 Motherboard Replacement: paso 11, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 11, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 11, imagen 3 de 3
    • Locate the following:
    • Two positive battery terminals.
    • Two positive battery wire glue-points.
    • This glue may separate from the motherboard while detaching the battery terminals, but this has no significant impact on the device.
    • Gluing any separated wires back to the motherboard is an optional reassembly step.
    • One terminal at a time, insert a narrow metal spudger through the metal loop of each terminal from the side and pry upwards away from the front cover to release the terminal from the cover.
    • A metal spudger is used because it requires significant force to release the positive battery terminals.
  12. LeapFrog LeapPad 2 Motherboard Replacement: paso 12, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 12, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 12, imagen 3 de 3
    • Two negative battery terminals.
    • Two negative battery wire glue-points.
    • One terminal at a time, pinch the battery side of the terminal towards the wire side of the terminal with a finger or thumb, and pull upwards away from the front cover to release the terminal from the cover.
    • The negative battery terminals require much less force to remove than the positive battery terminals.
  13. LeapFrog LeapPad 2 Motherboard Replacement: paso 13, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 13, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 13, imagen 3 de 3
    • Use the small plastic opening tool to gently lift under the side microphone's black wire to remove the microphone from its slot.
  14. LeapFrog LeapPad 2 Motherboard Replacement: paso 14, imagen 1 de 1
    • Holding the front cover with one hand and the sides of the motherboard with the other, lift the motherboard away from the front cover.
    • The following may become loose and fall out of position. Reposition them if necessary.
    • Front camera lens.
    • Buttons.
  15. LeapFrog LeapPad 2 Motherboard Replacement: paso 15, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 15, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 15, imagen 3 de 3
    • If the bracket did not previously fall out after removal of the game cartridge slot screws, remove it now and set it aside for reassembly.
    • Front camera bracket location.
  16. LeapFrog LeapPad 2 Motherboard Replacement: paso 16, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement: paso 16, imagen 2 de 2
    • The rubber screen border may separate on its own after removing the front cover from the screen assembly and motherboard. Set it aside if it comes off.
    • Pay attention to the original orientation of the rubber screen border to facilitate reassembly.
  17. LeapFrog LeapPad 2 Motherboard Replacement, Separate Motherboard and Screen Assembly: paso 17, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement, Separate Motherboard and Screen Assembly: paso 17, imagen 2 de 2
    • Screen assembly tab locations.
    • Slide the motherboard in the direction of the game cartridge slot until the motherboard is out from under the metal tabs on the screen assembly.
  18. LeapFrog LeapPad 2 Motherboard Replacement: paso 18, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement: paso 18, imagen 2 de 2
    • Carefully flip the motherboard over by pivoting away from the screen assembly along the long edge with the microphone and speaker, as shown.
    • The motherboard and screen assembly are still connected by a ribbon cable that can be damaged if stressed severely.
  19. LeapFrog LeapPad 2 Motherboard Replacement, Front Camera: paso 19, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement, Front Camera: paso 19, imagen 2 de 2
    • Peel back the tape on the camera ribbon cable connector.
  20. LeapFrog LeapPad 2 Motherboard Replacement: paso 20, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 20, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 20, imagen 3 de 3
    • Open the camera connector by lifting on the brown latch with a plastic opening tool or a finger until it is in a vertical position.
    • Gently pull on the front camera ribbon cable and it should easily slide out of the connecter.
  21. LeapFrog LeapPad 2 Motherboard Replacement, Screen Assembly: paso 21, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement, Screen Assembly: paso 21, imagen 2 de 2
    • Peel back the tape on the display ribbon cable connector.
    • The front camera is shown removed in these images, but its removal is optional for most tasks.
  22. LeapFrog LeapPad 2 Motherboard Replacement: paso 22, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 22, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 22, imagen 3 de 3
    • Open the display connector by lifting on the brown latch with a plastic opening tool or a finger until it is in a vertical position.
    • Gently pull on the display ribbon cable and it should easily slide out of the connecter.
  23. LeapFrog LeapPad 2 Motherboard Replacement: paso 23, imagen 1 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 23, imagen 2 de 3 LeapFrog LeapPad 2 Motherboard Replacement: paso 23, imagen 3 de 3
    • The screen assembly is now separated.
  24. LeapFrog LeapPad 2 Motherboard Replacement, Motherboard: paso 24, imagen 1 de 2 LeapFrog LeapPad 2 Motherboard Replacement, Motherboard: paso 24, imagen 2 de 2
    • The motherboard is now separated.
Conclusión
Chase Mamatey
Miembro Desde 10/05/16
326 Reputación
9 Guías creadas
Equipo
USF Tampa, Team 1-5, Sullivan Fall 2016 Miembro de USF Tampa, Team 1-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G5
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 713
