Saltar al contenido principal
Leader Impression i10A-LE Speakers Replacement
Qué necesitas
  1. Leader Impression i10A-LE Speakers  Replacement, Speakers: paso 1, imagen 1 de 1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Speakers  Replacement: paso 2, imagen 1 de 3 Leader Impression i10A-LE Speakers  Replacement: paso 2, imagen 2 de 3 Leader Impression i10A-LE Speakers  Replacement: paso 2, imagen 3 de 3
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Speakers  Replacement: paso 3, imagen 1 de 3 Leader Impression i10A-LE Speakers  Replacement: paso 3, imagen 2 de 3 Leader Impression i10A-LE Speakers  Replacement: paso 3, imagen 3 de 3
    • Use the spudger to pry both of the speakers from the tablet.
    • Follow both sets of speaker wires to the motherboard where they are connected.
    • Desolder the wire connections from the motherboard.
Conclusión
jcg
Miembro Desde 11/14/16
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 130
