Saltar al contenido principal
Leader Impression i10A-LE Microphone Replacement
Qué necesitas
  1. Leader Impression i10A-LE Microphone Replacement, Microphone: paso 1, imagen 1 de 1
    • Orient your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Microphone Replacement: paso 2, imagen 1 de 3 Leader Impression i10A-LE Microphone Replacement: paso 2, imagen 2 de 3 Leader Impression i10A-LE Microphone Replacement: paso 2, imagen 3 de 3
    • Pry the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Microphone Replacement: paso 3, imagen 1 de 2 Leader Impression i10A-LE Microphone Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the positive and negative battery leads.
    • Remove the microphone from plastic housing with the tweezers.
    • Desolder the positive (red) and negative (black) power leads.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 115
