Saltar al contenido principal
Introducción
This replacement guide will teach you how to remove and replace the front facing camera to your Leader Impression i10A-LE tablet. This fix can take anywhere from 5-10 minutes.
Partes
No se especificaron partes.
  1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: paso 1, imagen 1 de 2 Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: paso 1, imagen 2 de 2
    • Start by prying the back off by using plastic opening tools.
    • Slide the flat end of the plastic tools into the seam device.
    • Using another plastic tool, slowly pry along the seam until the back pops off.
  2. Leader Impression i10A-LE Front Facing Camera Replacement: paso 2, imagen 1 de 1
    • Reminder to disconnect the battery.
    • Locate the Camera in the top left corner of the Leader Impression.
    • Using the tweezers, remove the bottom of the camera from the motherboard.
    • The top of the camera will detach as you pull upward.
  3. Leader Impression i10A-LE Front Facing Camera Replacement: paso 3, imagen 1 de 1
    • Remove the camera from it's slot.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 98
