Saltar al contenido principal
Leader Impression i10A-LE Battery Pack Replacement
Qué necesitas
  1. Leader Impression i10A-LE Battery Pack Replacement, Battery Pack: paso 1, imagen 1 de 1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Battery Pack Replacement: paso 2, imagen 1 de 3 Leader Impression i10A-LE Battery Pack Replacement: paso 2, imagen 2 de 3 Leader Impression i10A-LE Battery Pack Replacement: paso 2, imagen 3 de 3
    • Use the plastic prying tools to crack open the back of the device.
    • Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
    • Remove the back panel and set aside.
  3. Leader Impression i10A-LE Battery Pack Replacement: paso 3, imagen 1 de 2 Leader Impression i10A-LE Battery Pack Replacement: paso 3, imagen 2 de 2
    • The battery pack is glued to the device.
    • Use a spudger to pry the battery pack from the glue.
    • Desolder the positive (red) and negative (black) power leads.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 574
