Saltar al contenido principal
Introducción
This replacement guide will teach you how to remove and replace the back facing camera to your Leader Impression i10A-LE tablet. This fix can take anywhere from 15-25 minutes.
Partes
No se especificaron partes.
  1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: paso 1, imagen 1 de 2 Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: paso 1, imagen 2 de 2
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Back Facing Camera Replacement: paso 2, imagen 1 de 3 Leader Impression i10A-LE Back Facing Camera Replacement: paso 2, imagen 2 de 3 Leader Impression i10A-LE Back Facing Camera Replacement: paso 2, imagen 3 de 3
    • Start by prying the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Back Facing Camera Replacement: paso 3, imagen 1 de 3 Leader Impression i10A-LE Back Facing Camera Replacement: paso 3, imagen 2 de 3 Leader Impression i10A-LE Back Facing Camera Replacement: paso 3, imagen 3 de 3
    • Once the back is off, locate the back facing camera.
    • The camera will be in the top left corner.
    • Using the precision tweezers that are bent, gently grab the strip below the camera.
    • slowly lift up until the camera lifts from its spot.
  4. Leader Impression i10A-LE Back Facing Camera Replacement: paso 4, imagen 1 de 3 Leader Impression i10A-LE Back Facing Camera Replacement: paso 4, imagen 2 de 3 Leader Impression i10A-LE Back Facing Camera Replacement: paso 4, imagen 3 de 3
    • Continue slowly lifting with the bent precision tweezers.
    • The bottom half of the camera strip will pop out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 159
