Saltar al contenido principal
Le Pan S Camera Replacement
Qué necesitas
  1. Le Pan S Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Camera Replacement: paso 2, imagen 1 de 2 Le Pan S Camera Replacement: paso 2, imagen 2 de 2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Camera Replacement: paso 3, imagen 1 de 1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Camera Replacement: paso 4, imagen 1 de 2 Le Pan S Camera Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
  5. Le Pan S Camera Replacement, Camera: paso 5, imagen 1 de 1
    • Remove the four 3.5 mm Phillips #00 screws from the circuit board near the bottom of the tablet.
  6. Le Pan S Camera Replacement: paso 6, imagen 1 de 1
    • Lift and pull the volume rocker up so it is out of the way of the camera.
  7. Le Pan S Camera Replacement: paso 7, imagen 1 de 2 Le Pan S Camera Replacement: paso 7, imagen 2 de 2
    • Remove the zero insertion force connector (ZIF) by using a plastic opening tool, spudger, or fingernail to lift retaining flap.
  8. Le Pan S Camera Replacement: paso 8, imagen 1 de 2 Le Pan S Camera Replacement: paso 8, imagen 2 de 2
    • Slightly lift up the green electrical board and pull out the camera.
Conclusión
Tyler Ziliak
Miembro Desde 09/17/15
110 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-1, Harley Fall 2015 Miembro de IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 249
