Introducción
If the images taken are black or not displayed at all, it may be time to replace the camera. Replacing the camera is a moderately easy task, and the step-by-step disassembly is listed below. No out-of-the-ordinary tools will be required for this guide.
Qué necesitas
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
Remove the four 3.5 mm Phillips #00 screws from the circuit board near the bottom of the tablet.
