Introducción
If the battery is too low for the device to turn on, replacing the battery may be necessary. If the device does not turn on after charging, the battery is most likely completely dead. When a battery is completely discharged, it oftentimes cannot be recharged. In this case, the battery is dead and needs to be replaced. No special skills or tools will be needed in order to complete this guide.
Qué necesitas
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
3 personas más completaron esta guía.
5 comentarios
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
