Saltar al contenido principal
Le Pan II Motherboard Replacement
Qué necesitas
  1. Le Pan II Motherboard Replacement, Screen: paso 1, imagen 1 de 2 Le Pan II Motherboard Replacement, Screen: paso 1, imagen 2 de 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Motherboard Replacement: paso 2, imagen 1 de 2 Le Pan II Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Motherboard Replacement: paso 3, imagen 1 de 2 Le Pan II Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove grey metal backing from screen.
  5. Le Pan II Motherboard Replacement: paso 5, imagen 1 de 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Motherboard Replacement: paso 6, imagen 1 de 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Motherboard Replacement, Battery: paso 7, imagen 1 de 1
    • Use the plastic opening tool to push out the wires connecting the battery to the motherboard and put battery aside.
  8. Le Pan II Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Use the Plillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should 8 (3.5mm) screws
  9. Le Pan II Motherboard Replacement: paso 9, imagen 1 de 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1 mm) screws for the fan.
    • Note: From here, you can simply lift and remove the motherboard from the rest of the device.
Conclusión
Kelly Moniz
Miembro Desde 10/20/16
513 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 6-3, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 174
