Saltar al contenido principal
Le Pan II Camera Replacement
Qué necesitas
  1. Le Pan II Camera Replacement, Screen: paso 1, imagen 1 de 2 Le Pan II Camera Replacement, Screen: paso 1, imagen 2 de 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Camera Replacement: paso 2, imagen 1 de 2 Le Pan II Camera Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Camera Replacement: paso 3, imagen 1 de 2 Le Pan II Camera Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Camera Replacement: paso 4, imagen 1 de 1
    • Remove grey metal backing from screen.
  5. Le Pan II Camera Replacement: paso 5, imagen 1 de 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Camera Replacement: paso 6, imagen 1 de 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Camera Replacement, Camera: paso 7, imagen 1 de 1
    • Use the plastic opening tool to lift the connector up and remove the camera.
Conclusión
Kelly Moniz
Miembro Desde 10/20/16
513 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 6-3, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 71
