Saltar al contenido principal
Introducción
In this guide, you will be shown step-by-step how to replace your Le Pan II battery.
Partes
No se especificaron partes.
  1. Insert metal spudger between front and back panel to pry apart. Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector. Disconnect the flat ribbon by gently pulling it out from its connecting port.
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Use the plastic opening tool to disconnect the display cable from its motherboard connector. Disconnect the display cable by gently pulling it out from its connecting port.
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  5. Remove grey metal backing from screen.
    • Remove grey metal backing from screen.
  6. Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  7. Lift and carefully remove the LCD display from the front cover.
    • Lift and carefully remove the LCD display from the front cover.
  8. Use the plastic opening tool to push out the wires connecting the battery to the motherboard and put battery aside.
    • Use the plastic opening tool to push out the wires connecting the battery to the motherboard and put battery aside.
Conclusión
Kelly Moniz
Miembro Desde 20/10/16
501 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 6-3, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 6
Últimos 30 Días: 22
Todo El Tiempo: 823
