Saltar al contenido principal
Lasko 4910 Filter Replacement
Qué necesitas
  1. Lasko 4910 Filter Replacement, Filter: paso 1, imagen 1 de 1
    • On the backside of the fan, remove the top two 4mm Phillips #Y1 screws using PH 1 bit and Magnetic Driver
  2. Lasko 4910 Filter Replacement: paso 2, imagen 1 de 1
    • Remove the top plastic portion of the fan
  3. Lasko 4910 Filter Replacement: paso 3, imagen 1 de 1
    • Remove all four 4mm screws using the Phillips #1 screwdriver.
  4. Lasko 4910 Filter Replacement: paso 4, imagen 1 de 1
    • Remove the filter from the fan.
Conclusión
Julie Ling
Miembro Desde 10/22/18
159 Reputación
1 Guía escrita
Equipo
UC Davis, Team S11-G2, Lore Fall 2018 Miembro de UC Davis, Team S11-G2, Lore Fall 2018
UCD-LORE-F18S11G2
Miembros de 4
1 Guía escrita
Un comentario
Thank you for taking the time to do this. A great little guide for a fan that doesn't have a lot of support. Most details are looked over in online guide material. But this one was done with professional care.
Sincerely,
Davis Steffens
Seattle, WA
davissteffens@hotmail.com
PS: I Fix-It represents more than a company providing a service. I think you are reminding everyone that we have the right to Fix. Which in these weird times is a step needed.
Davis Steffens - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 1,725
