Saltar al contenido principal
Lasko 2002W Motor Replacement
Qué necesitas
  1. Lasko 2002W Motor Replacement, Remove cover: paso 1, imagen 1 de 1
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: paso 2, imagen 1 de 1
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: paso 3, imagen 1 de 1
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: paso 4, imagen 1 de 1
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: paso 5, imagen 1 de 1
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
Conclusión
9 personas más completaron esta guía.
elsa
Miembro Desde 10/11/14
382 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-39, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-39, Donnelly Fall 2014
USFT-DONNELLY-F14S1G39
1 Miembro
1 Guía escrita
Un comentario
What is the part number for replacement motor? Where do you get it?
Paul Dias - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 37
Todo El Tiempo: 3,563
