Saltar al contenido principal
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
Qué necesitas
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: paso 1, imagen 1 de 1
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 2, imagen 1 de 1
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 3, imagen 1 de 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 3, imagen 2 de 2
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 4, imagen 1 de 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 4, imagen 2 de 2
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 5, imagen 1 de 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 5, imagen 2 de 2
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 6, imagen 1 de 1
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 7, imagen 1 de 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 7, imagen 2 de 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 7, imagen 3 de 3
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 8, imagen 1 de 1
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 9, imagen 1 de 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 9, imagen 2 de 2
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 10, imagen 1 de 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 10, imagen 2 de 2
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: paso 11, imagen 1 de 1
    • Gently pull the hose to ensure it is secure.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 752
