Saltar al contenido principal
LG-P970 touch screen Replacement
Qué necesitas
  1. LG-P970 touch screen Replacement, touch screen: paso 1, imagen 1 de 3 LG-P970 touch screen Replacement, touch screen: paso 1, imagen 2 de 3 LG-P970 touch screen Replacement, touch screen: paso 1, imagen 3 de 3
    • remove the back cover
    • remove the battery
    • remove the SIM card
    • remove the µSD card (Memory)
  2. LG-P970 touch screen Replacement: paso 2, imagen 1 de 3 LG-P970 touch screen Replacement: paso 2, imagen 2 de 3 LG-P970 touch screen Replacement: paso 2, imagen 3 de 3
    • remove 7 screws on the back
    • with a tool start to open the back frame
    • and it's now easy to remove the back frame with hand, carefully
  3. LG-P970 touch screen Replacement: paso 3, imagen 1 de 3 LG-P970 touch screen Replacement: paso 3, imagen 2 de 3 LG-P970 touch screen Replacement: paso 3, imagen 3 de 3
    • remove buttons
    • locate the back camera
    • with a tool raise up the led.carefully
  4. LG-P970 touch screen Replacement: paso 4, imagen 1 de 3 LG-P970 touch screen Replacement: paso 4, imagen 2 de 3 LG-P970 touch screen Replacement: paso 4, imagen 3 de 3
    • with a tool disconnect the back camera
    • and remove the camera with your fingers.
  5. LG-P970 touch screen Replacement: paso 5, imagen 1 de 2 LG-P970 touch screen Replacement: paso 5, imagen 2 de 2
    • don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
  6. LG-P970 touch screen Replacement: paso 6, imagen 1 de 3 LG-P970 touch screen Replacement: paso 6, imagen 2 de 3 LG-P970 touch screen Replacement: paso 6, imagen 3 de 3
    • It's time to remove carefully the tactile screen.
    • don't scratch le LCD!!!
  7. LG-P970 touch screen Replacement: paso 7, imagen 1 de 3 LG-P970 touch screen Replacement: paso 7, imagen 2 de 3 LG-P970 touch screen Replacement: paso 7, imagen 3 de 3
    • the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
    • cut new double sided tape (1-2mm width), put it on the are and peel it.
  8. LG-P970 touch screen Replacement: paso 8, imagen 1 de 3 LG-P970 touch screen Replacement: paso 8, imagen 2 de 3 LG-P970 touch screen Replacement: paso 8, imagen 3 de 3
    • remove the inside protection on the new touch screen.
    • carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
    • to finish, add all part by reading these instructions in reverse ;-)
    • and try if it work !
Conclusión
19 personas más completaron esta guía.
Fox4EGX
Miembro Desde 10/01/12
545 Reputación
1 Guía escrita
Un comentario
Hi. To take the screws out do I need a phillips? Thanks.
schutze61 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 9,679
