Introducción
In this guide, you will see how to take apart the LG-A275 in order to replace the phone's speaker.
Qué necesitas
Paso 1 Battery
Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
Turn the phone upside down so that the bottom of the back is facing you.
Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
