Saltar al contenido principal
LG X Style Speaker Replacement
Qué necesitas
  1. LG X Style Speaker  Replacement, Screen: paso 1, imagen 1 de 2 LG X Style Speaker  Replacement, Screen: paso 1, imagen 2 de 2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  2. LG X Style Speaker  Replacement: paso 2, imagen 1 de 3 LG X Style Speaker  Replacement: paso 2, imagen 2 de 3 LG X Style Speaker  Replacement: paso 2, imagen 3 de 3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  3. LG X Style Speaker  Replacement, Battery: paso 3, imagen 1 de 1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  4. LG X Style Speaker  Replacement: paso 4, imagen 1 de 2 LG X Style Speaker  Replacement: paso 4, imagen 2 de 2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  5. LG X Style Speaker  Replacement, Speaker: paso 5, imagen 1 de 3 LG X Style Speaker  Replacement, Speaker: paso 5, imagen 2 de 3 LG X Style Speaker  Replacement, Speaker: paso 5, imagen 3 de 3
    • Insert the plastic opening tool into slit around speaker box on mid shield frame.
    • Gently pop up the speaker housing.
    • If the adhesive film doesn’t remove itself with the speaker housing, use the plastic opening tool to remove film.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 339
