Introducción
Use this guide to remove the front camera display on your LG device.
Qué necesitas
Power down the device and make sure that it is turned off.
Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
Gently twist tool clockwise until the back case pops open [this will create a small gap].
Slide the tool along the gap around the entire device.
Using a plastic opening tool, lift up display connection until disconnected from the lower right hand of the phone.
