Saltar al contenido principal
LG X Style Battery Replacement
Qué necesitas
  1. LG X Style Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Battery Replacement: paso 2, imagen 1 de 2 LG X Style Battery Replacement: paso 2, imagen 2 de 2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 954
