Saltar al contenido principal
LG X Power Screen Replacement
Qué necesitas
  1. LG X Power Screen Replacement, LG X Power Disassembly: paso 1, imagen 1 de 2 LG X Power Screen Replacement, LG X Power Disassembly: paso 1, imagen 2 de 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Screen Replacement: paso 2, imagen 1 de 2 LG X Power Screen Replacement: paso 2, imagen 2 de 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Screen Replacement: paso 3, imagen 1 de 2 LG X Power Screen Replacement: paso 3, imagen 2 de 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Screen Replacement, Battery: paso 4, imagen 1 de 3 LG X Power Screen Replacement, Battery: paso 4, imagen 2 de 3 LG X Power Screen Replacement, Battery: paso 4, imagen 3 de 3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Screen Replacement: paso 5, imagen 1 de 1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Screen Replacement: paso 6, imagen 1 de 1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Screen Replacement: paso 7, imagen 1 de 2 LG X Power Screen Replacement: paso 7, imagen 2 de 2
    • Use a spudger and plastic opening tool to carefully pry up the battery.
    • There is a strong adhesive on the back of the battery that will make it difficult to remove.
  8. LG X Power Screen Replacement, Screen: paso 8, imagen 1 de 2 LG X Power Screen Replacement, Screen: paso 8, imagen 2 de 2
    • Carefully peal off the glued vibration motor by using the plastic opening tool.
  9. LG X Power Screen Replacement: paso 9, imagen 1 de 2 LG X Power Screen Replacement: paso 9, imagen 2 de 2
    • Using the plastic opening tool, pry off the ear speaker.
Conclusión
16 personas más completaron esta guía.
Equipo
USF Tampa, Team S3-G6, Nance Spring 2018 Miembro de USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Miembros
12 Guías creadas
7 comentarios
If you are just replacing the screen, this is wrong. This would help if you are replacing with a “screen in frame”
asears - Contestar
What is the right way for just the screen?
Kodi Butscha -
Please add “with frame” in title. Also need to make sure all contacts are present on the frame of the new screen, transfer them over if not.
rian_bay - Contestar
Is the x power screen the same size ( or same screen altogether) as the x power 3 screen? If not what screen would I be looking for?
Jonathan - Contestar
Where’s the part where you actually remove the screen and add in the new one?
The last step seems to be prying off the ear speaker.
Could you please fix this guide when you get the chance? I might replace the screen on my LG Power X [K210]. Thanks.
A Mix Of Geek Stuff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 8,241
