Saltar al contenido principal
LG X Power Charging Port Replacement
Qué necesitas
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: paso 1, imagen 1 de 2 LG X Power Charging Port Replacement, LG X Power Disassembly: paso 1, imagen 2 de 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: paso 2, imagen 1 de 2 LG X Power Charging Port Replacement: paso 2, imagen 2 de 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: paso 3, imagen 1 de 2 LG X Power Charging Port Replacement: paso 3, imagen 2 de 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: paso 4, imagen 1 de 3 LG X Power Charging Port Replacement, Charging Port: paso 4, imagen 2 de 3 LG X Power Charging Port Replacement, Charging Port: paso 4, imagen 3 de 3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: paso 5, imagen 1 de 1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: paso 6, imagen 1 de 1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: paso 7, imagen 1 de 1
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
Conclusión
5 personas más completaron esta guía.
Chad Sears
Miembro Desde 02/14/18
1,170 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S3-G6, Nance Spring 2018 Miembro de USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Miembros
12 Guías creadas
Un comentario
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 5,926
