Introducción
In order to replace your screen you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, PH #000 screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the screen for the LG Watch Urbane.
Qué necesitas
Herramienta utilizada en este paso:Tweezers$4.99
Push on the band in order to expose the pins
Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
Herramienta utilizada en este paso:Magnetic Project Mat$16.96
Now that you have removed the motherboard and battery, it is time to remove the dock connector.
Using a PH000 screwdriver, remove the two screws in order to release the dock connector from the watch.
Una persona más ha completado esta guía.
2Guía Comentarios
where i can find watch urbane display ?
Does anyone know where to buy the display?
