Saltar al contenido principal
LG Watch Urbane Battery Replacement
Qué necesitas
  1. LG Watch Urbane Battery Replacement, Battery: paso 1, imagen 1 de 2 LG Watch Urbane Battery Replacement, Battery: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Replacement: paso 2, imagen 1 de 2 LG Watch Urbane Battery Replacement: paso 2, imagen 2 de 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Replacement: paso 3, imagen 1 de 3 LG Watch Urbane Battery Replacement: paso 3, imagen 2 de 3 LG Watch Urbane Battery Replacement: paso 3, imagen 3 de 3
    Magnetic Project Mat
    $19.95
    Comprar
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Replacement: paso 4, imagen 1 de 3 LG Watch Urbane Battery Replacement: paso 4, imagen 2 de 3 LG Watch Urbane Battery Replacement: paso 4, imagen 3 de 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
Conclusión
18 personas más completaron esta guía.
Rey Diaz
Miembro Desde 08/31/15
699 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-4, Remmell Fall 2015 Miembro de USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Miembros
4 Guías creadas
11 comentarios
"pried" not "pryed"
Patty Remmell - Contestar
Where do I find a replacement battery?
nickpfau - Contestar
Found mine on ebay. Search for BL-S3 battery.
Atreidae -
The reassembly requires gluing the back together. How do you get the glue?
jiteshshahin - Contestar
There is glue around cover. I suppose when closing we should add glue to be waterproof again? Nothing about it in the guide, beside that ok.
Imx - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 50
Todo El Tiempo: 15,402
