Introducción
Use this guide to replace the inlet valve filters in your LG WM3050CW Washing Machine.
The inlet valve filters block debris from the water inlet hoses. These filters can get clogged with sediment, which slows down the tub filling process.
Qué necesitas
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
Remove the filters.
Repair didn’t go as planned? Ask our Answers community for help.
