Saltar al contenido principal
LG WM3050CW Drain Hose Replacement
Qué necesitas
  1. LG WM3050CW Drain Hose Replacement, Safety Precautions: paso 1, imagen 1 de 2 LG WM3050CW Drain Hose Replacement, Safety Precautions: paso 1, imagen 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Drain Hose Replacement, Unfasten the top panel: paso 2, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Unfasten the top panel: paso 2, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Unfasten the top panel: paso 2, imagen 3 de 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Drain Hose Replacement, Remove the top panel: paso 3, imagen 1 de 2 LG WM3050CW Drain Hose Replacement, Remove the top panel: paso 3, imagen 2 de 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Drain Hose Replacement: paso 4, imagen 1 de 2 LG WM3050CW Drain Hose Replacement: paso 4, imagen 2 de 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Drain Hose Replacement, Remove the detergent drawer: paso 5, imagen 1 de 2 LG WM3050CW Drain Hose Replacement, Remove the detergent drawer: paso 5, imagen 2 de 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG WM3050CW Drain Hose Replacement: paso 6, imagen 1 de 3 LG WM3050CW Drain Hose Replacement: paso 6, imagen 2 de 3 LG WM3050CW Drain Hose Replacement: paso 6, imagen 3 de 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG WM3050CW Drain Hose Replacement, Disconnect the control panel: paso 7, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Disconnect the control panel: paso 7, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Disconnect the control panel: paso 7, imagen 3 de 3
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG WM3050CW Drain Hose Replacement, Unfasten the control panel: paso 8, imagen 1 de 2 LG WM3050CW Drain Hose Replacement, Unfasten the control panel: paso 8, imagen 2 de 2
    • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
  9. LG WM3050CW Drain Hose Replacement, Unfasten the detergent dispenser: paso 9, imagen 1 de 1
    • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
  10. LG WM3050CW Drain Hose Replacement, Unclip the control panel: paso 10, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Unclip the control panel: paso 10, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Unclip the control panel: paso 10, imagen 3 de 3
    • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
    • Twist the screwdriver to release the clips securing the control panel.
    • Repeat this procedure for the remaining clips along the control panel.
  11. LG WM3050CW Drain Hose Replacement, Remove the control panel: paso 11, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Remove the control panel: paso 11, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Remove the control panel: paso 11, imagen 3 de 3
    • Lift the control panel upward to completely separate it from the chassis.
    • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
    • Remove the control panel.
  12. LG WM3050CW Drain Hose Replacement, Open the door: paso 12, imagen 1 de 2 LG WM3050CW Drain Hose Replacement, Open the door: paso 12, imagen 2 de 2
    • Open the front door completely.
  13. LG WM3050CW Drain Hose Replacement, Remove the boot ring: paso 13, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Remove the boot ring: paso 13, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Remove the boot ring: paso 13, imagen 3 de 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG WM3050CW Drain Hose Replacement: paso 14, imagen 1 de 3 LG WM3050CW Drain Hose Replacement: paso 14, imagen 2 de 3 LG WM3050CW Drain Hose Replacement: paso 14, imagen 3 de 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • This procedure will take significant force.
  15. LG WM3050CW Drain Hose Replacement, Disconnect the boot: paso 15, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Disconnect the boot: paso 15, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Disconnect the boot: paso 15, imagen 3 de 3
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG WM3050CW Drain Hose Replacement: paso 16, imagen 1 de 3 LG WM3050CW Drain Hose Replacement: paso 16, imagen 2 de 3 LG WM3050CW Drain Hose Replacement: paso 16, imagen 3 de 3
    • Work your fingers around the boot until its completely separated from the panel.
  17. LG WM3050CW Drain Hose Replacement, Remove the filter panel: paso 17, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Remove the filter panel: paso 17, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Remove the filter panel: paso 17, imagen 3 de 3
    • Open the filter panel at the bottom left of the front panel.
    • Twist the filter panel upward to unclip it from the front panel.
  18. LG WM3050CW Drain Hose Replacement, Unfasten the filter trim: paso 18, imagen 1 de 1
    • Use a Phillips driver to remove the two 12.8 mm‑long screws securing the filter trim.
  19. LG WM3050CW Drain Hose Replacement, Remove the filter trim: paso 19, imagen 1 de 2 LG WM3050CW Drain Hose Replacement, Remove the filter trim: paso 19, imagen 2 de 2
    • Pull the filter trim straight off the front panel to remove it.
  20. LG WM3050CW Drain Hose Replacement, Unfasten the lower front panel: paso 20, imagen 1 de 1
    • Use a Phillips driver to remove the 12.8 mm-long screw securing the lower front panel.
  21. LG WM3050CW Drain Hose Replacement, Unfasten the door latch: paso 21, imagen 1 de 1
    • Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
  22. LG WM3050CW Drain Hose Replacement, Remove the door latch: paso 22, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Remove the door latch: paso 22, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Remove the door latch: paso 22, imagen 3 de 3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  23. LG WM3050CW Drain Hose Replacement, Unfasten the front panel: paso 23, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Unfasten the front panel: paso 23, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Unfasten the front panel: paso 23, imagen 3 de 3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Use a Phillips driver, or a 7 mm nut driver, to remove the six 15 mm‑long screws securing the front panel.
  24. LG WM3050CW Drain Hose Replacement, Remove the front panel: paso 24, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Remove the front panel: paso 24, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Remove the front panel: paso 24, imagen 3 de 3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  25. LG WM3050CW Drain Hose Replacement: paso 25, imagen 1 de 1
    • Remove the front panel.
  26. LG WM3050CW Drain Hose Replacement, Unfasten the rear panel: paso 26, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Unfasten the rear panel: paso 26, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Unfasten the rear panel: paso 26, imagen 3 de 3
    • Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
  27. LG WM3050CW Drain Hose Replacement, Remove the rear panel: paso 27, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Remove the rear panel: paso 27, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Remove the rear panel: paso 27, imagen 3 de 3
    • Lift the rear panel upward to release its bottom clips.
    • Pull the rear panel away from the chassis to release the remaining clips.
  28. LG WM3050CW Drain Hose Replacement: paso 28, imagen 1 de 1
    • Remove the rear panel.
  29. LG WM3050CW Drain Hose Replacement, Disconnect the drain hose: paso 29, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Disconnect the drain hose: paso 29, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Disconnect the drain hose: paso 29, imagen 3 de 3
    • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
  30. LG WM3050CW Drain Hose Replacement: paso 30, imagen 1 de 3 LG WM3050CW Drain Hose Replacement: paso 30, imagen 2 de 3 LG WM3050CW Drain Hose Replacement: paso 30, imagen 3 de 3
    • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
    • Pull the drain hose straight off its connection on the assembly.
  31. LG WM3050CW Drain Hose Replacement, Unclip the drain hose: paso 31, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Unclip the drain hose: paso 31, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Unclip the drain hose: paso 31, imagen 3 de 3
    • The drain hose is clipped in the back left portion of the chassis.
    • While holding the back of clip with one hand, use the other to push the prongs of the clip and release them.
    • Repeat for each prong until the clip slides through the chassis.
  32. LG WM3050CW Drain Hose Replacement, Reposition the drain hose: paso 32, imagen 1 de 1
    • Reposition the drain hose so you can access the plastic clip.
  33. LG WM3050CW Drain Hose Replacement, Unfasten the drain hose: paso 33, imagen 1 de 1
    • Use a T20 Torx driver to remove the 12.9 mm-long screw securing the drain hose to the backside of the washer.
  34. LG WM3050CW Drain Hose Replacement, Apply the tape: paso 34, imagen 1 de 1
    • Apply some masking tape where the plastic clip is located to help reposition the clip during reassembly,
  35. LG WM3050CW Drain Hose Replacement, Remove the plastic clip: paso 35, imagen 1 de 3 LG WM3050CW Drain Hose Replacement, Remove the plastic clip: paso 35, imagen 2 de 3 LG WM3050CW Drain Hose Replacement, Remove the plastic clip: paso 35, imagen 3 de 3
    • Pull the plastic clip off the drain hose.
    • Remove the plastic clip.
  36. LG WM3050CW Drain Hose Replacement, Pull the drain hose: paso 36, imagen 1 de 2 LG WM3050CW Drain Hose Replacement, Pull the drain hose: paso 36, imagen 2 de 2
    • Pull the drain hose through its slot in the chassis.
  37. LG WM3050CW Drain Hose Replacement: paso 37, imagen 1 de 3 LG WM3050CW Drain Hose Replacement: paso 37, imagen 2 de 3 LG WM3050CW Drain Hose Replacement: paso 37, imagen 3 de 3
    • Rotate the end of the drain hose to maneuver it through its slot in the chassis.
    • Depending on the hose's position, you may need to slide the metal hose clamp further down the elbow.
    • Remove the drain hose.
    • Use your old drain hose to figure out and mark where the plastic retaining clip should attach onto the new hose.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Miembro Desde 06/30/22
30,797 Reputación
213 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,086 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 308
