If your LG Voyager camera is not working properly, you can replace it by following the steps in this guide.
Unscrew all four screws from the corners of the back cover.
Using a plastic opening tool, gently remove the back cover.
Gently press the replacement camera into the old one's place.
Replace all of the phone's removed parts, and you are ready to use your new camera.
Incrustar esta guía
Elige el tamaño y copia el siguiente código para insertar esta guía como un pequeño widget en tu sitio web o foro.
Vista previa
